larry harding
hi guys i'm usually on the model a forum, but need a little help from this one.
i built a 50's style model a speedster with a lightened flywheel, 9" clutch and a 39 ******. i built the ****** using van pelts book and parts from scrounged doners. i need help with a couple of problems.
#1 the ****** shifts really good and makes driving a pleasure except for one thing. if i let off the throttle in second gear and deaccelerate it will come out of gear. what do i need to look for?
#2 i have a good thick disc in the clutch, but the fingers don't look right. is there some info on the net on adjusting the fingers. i know they need to be adjusted to match the thickness of the disc while on the flywheel.
