ian Simpson
Unscrew the drain plug on the bottom of the transmission housing and drain the oil out. Reinstall the plug. Remove the plug on the side of the transmission case. Fill to spill, which means dump oil in until it spills over. Let it run off and reinstall the plug.
I buy my 600W from Bratton's, it comes in quart plastic squeeze bottles. Cut the tip off the snout and put your finger over it until you have the container at a proper angle and squeeze.
Some people will argue that the level should be a half inch below the side spill port. I don't think it makes much difference.
Finish up by poking a wire through the vent hole in the tower to make sure it is clear of crud.
Tom Endy
I recommend taking the fill plug out first. If it will not come out you could be left with an immobilized car with no oil in the transmission. (Same goes for rear axle.)
Ask me how I know.
Ian
