Thanks for the info.
It's a 57 Ford Fairlane with a 60 Merc 312. Been trying to track down a vibration, it comes in around 65-70 and lightens up a bit around 85-90. Thought at first it was tires so had a new set put on, still the same. Next replaced the rear Trans mount, then a different drive shaft. Also replaced the u- joints and the bushing in the rear of the Trans. Vibration stayed the same, the Trans will pop out of 2nd gear if you don't hold it in when letting off it , figure maybe the problem is in the Trans. I have a rebuilt T86 so thought we would give it a try.
Any suggestions would be very welcome, Thanks again.
