My 31 trans. has a very slow leak, maybe 6-7 drops after a 10 mile drive.
My quest. is will the trans. drain completley or will it stop dripping when it reaches a level below the shaft ?...Kinda like the water level in the rad. when it finds it's level.
When I service it I fill it untill it runs out of the filler hole, is that to much? or should it be maybe an inch below that?
It does not leak when not running. Thanks for any advice.
