Dal's Dream Car
OK. Putting the new top on the 29 Tudor. I have just about everything prepped. I ordered the rain gutters from Snyders. Following directions, I put wax paper between the base and the gutter and snapped it together in order to bend it to the contour on the back. Slowly got a good match on the contour without kinking or too much twisting. So far so good.....now how do I get the base off of the gutter without destroying it so that I can paint it and put it on the car? A screwdriver between the two pieces and prying kind of destroys the base. You cant slide it out cuz...a) the wax paper is holding and b) it has a contour in it now. Looking for some experience out there and I know its out there. If there is a Gent by the name of Larry Ryder out there, you wrote the bible for this top so far on; http://www.abarnyard.com/workshop/roofinstall-9.htm
It just doesn't give the finer points on this moulding. By the way, mine is almost the exact same car color and all. This pictorial is a superb step-by-step on how to do this.
