Also for oldtimers tirepressure advice is all about load on tire and speed you drive.
So if you can produce car weight in use and best weighed per wheel, and of tires if diagonal or radial, maximumm load or loadindex, Needed pressure for that wich is not the maximum allowed cold pressure , and called maxloadpressure/referencepressure/AT-pressure, and is related to the loadrange, mostly given on sidewall. Then I can calculate a save lowest pressure or one with some reserve but no bumping.
Also need maximum speed of tire and that you use and wont go over for even a minute.
Try to produce this and I will calculate.
Greatings from A Dutch Pigheaded Selfdeclared tirepressure-specialist.
Peter
And nice hollidays and a good 2016 from the other side of the ocean.
Peter
