My 31 sport coupe started to run a little poorly. The problem seemed to be either trash in the carborator or an electrial problem of some sort. I began with the electrical by cleaning and gapping plugs, checking the wiring on the and conditon of the (modern) upper and lower plates, filing and gapping the points, and finally timing (twice) with a NU-REX wrench. The problem now is that the timing seems to be too advanced. The engine will start just fine at full retard but will die (at idle) before reaching full advance. When running the car I keep it at full retard until 30mph +/- then advance two or three clicks. I recently had new babbets poured and the engine was running fine. Any ideas on what could be causing the advaced idle and possible solutions.
