Bruce Adams
Hi Skip,
To take up the "slop" without doing it correctly by rebuilding your distributor, you can try taking up the slop in the cam by rotating the cam clockwise, taking up the "slop", and then loosen the screw and rotate it, clockwise while at TDC until the points JUST CLOSE, which is the same as rotating CCW until they just START OPENING.
This should give you a good starting point.
