With all due respect; the answers to palmaceae are useful, but I don't think we are leading him in the correct direction.
I have 1/8" rotational play in my distributor, and the timing works exactly as it should. I have good power, optimum water temperature, and good gas mileage. In my opinion rotational play has no bad affect. However, if the bushing to shaft fit is loose, or the points mounting plate is loose; then I do agree they will affect timing.
When setting my timing, I make sure I take up the rotational play before tightening the point cam screw. Normally, that rotational play is taken up when the motor is running. To check my timing, I retard the spark lever fully; then while holding the coil wire near a head bolt I advance the spark lever, and within one or to notches a spark should occur. If not, I readjust the point cam position until it does.
As long as palmaceae doesn't have excess play in the shaft/bushing, or in the points mounting plate; he should be able to time his Model A and it will run correctly.
I have not deduced what palmaceae's problem is. I want to think (as mentioned above) that the timing is too far advanced. I would have to get my hands on it to see if I could solve his problem.
I see we both live in Iowa, but I am in east-central, and he is in the NW. I'm afraid that would not be a short commute.
I hope this information helps.
palmaceae - That is a good question; someone on Fordbarn once stated timing will change with point gap adjustment. But I haven't convinced myself that happens (I haven't visualize the idea). I do know that point gap affects coil saturation. The closer that gap, the more saturation, and vise-a-versa.
I have always wanted to play with my timing by just adjusting the point gap, but haven't yet. I like driving the car too much, and tend to just maintain and fix when necessary.
I think you stated you have a cam wrench. I don't, but sometimes wished I did. I would think you can make finer adjustments to cam position using that wrench. I have noticed some of the vendors have a degree wheel you can put on the distirbutor, and using the wrench with said wheel make adjustments. Maybe that's what you need to see just how much that last adjustment was.
All I can say for right now is to keep trying. Is there a MAFCA or MARC club in your area? If so, maybe a knowledgable member in that club could look things over.
KenB has a very good point. Same issue, spark advance was not all the way retarded or advanced.
2 tooth steering? Loosen the bracket and rotate the steering column so that the spark advance touches both sides of the dist body.
Rob
Just checking the basics...(I learned this the hard way).
You need to use a cam wrench to hold the cam while you tighten the cam screw. Also, approach the turning of the cam to find the "break point" in the directions (CW or CCW) as shown in the Andrews book. Makes a BIG difference.
Marc
Once you have found TDC thru the sparkler hole then you may have better luck finding it with the timing pin.. You'll be able to swing the crankshaft 5-10 degrees or so without moving the piston so locating the hole/dimple in the camshaft gear is pretty important.. The dimples in some replacement gears are/is pretty small and hard to feel at times, grinding a bit more of a point on the timing pin helps or even using a scratch awl or small phillips screwdriver.. Removing all the sparklers makes it easier to spin the engine by hand..
