B_man_Al
Here's what I did last week with a cam nut that came loose.
Drilled two holes in the cam nut, half way between the IS and OS diameter of the nut. Tapped these holes with a 1/4 in. coarse thread tap. Made a small plate out of 1/4 in steel with corresponding holes for two 1/4 in bolts. Welded an old lug nut (13/16) to the center of the plate to get a torque wrench on. Screwed the two together ( loosely as the cam sticks out past the end of the gear when fully seated) Added "blue" locktite and torqued to 110 ft lbs. So far so good.
