Buss,
The carb you are talking about is a F1B, the only thing, I believe, that is available is the gasket set; Smith and Jones Antique Auto Parts, 1-800-422-1928.
The carb runs good if you clean all the passages; as a example, there is a seal on the mounting bolt that holds the two halves together, the reason is, the gas is around this bolt and there are two small passage-ways for gas in the lower housing above the bolt head. The F1B is also made of a ferious metal and sometimes you have to install heli-coils when the mounting bolts to intake manifold strip out.
If you plan on rebuilding be sure you have all the jets, if not, look for a spare for parts.
I can send you a article that shows all the passage-ways.
Frankly I think you would be better with a original Zenith or Holley as all parts are available, they re cast iron and most are very re-buildable.
Send me a PM if you want the F1B article.
Ron
