When installing the throttle plate, back off speed adjusting screw, insert throttle plate and start screws into shaft, push forward on throttle lever and allow throttle plate to center inself. tighten throttle plate screws. You will find that only the top hole in the front of the throat is visable.
Use standard procedure for setting air adjustment needle; to start, seat needle then open 1 and 1/2 turns; this should put you in the ball park.
Ron Rude
