30ccpickup
For a short tutorial on posting a picture on the Ford Barn when starting a new thread open the below attachment Posting Pictures.pdf. The directions are the same when adding a picture to someone else's thread. The only difference is you start at the bottom of their thread by clicking on Go Advance under Quick Reply. (Scroll to the bottom of this thread and you will see what I am talking about.)
If your picture is to large:
Open your picture in PAINT (Start-All Programs-Accessories-Paint). In Paint open Image-Stretch/Skew change your Horizontal and Vertical precentages to something smaller, the percentages must be the same. Re-save your work under a defferent name.
Additional tip: When saving, below Filename: is Save as type: change it to JPEG.
Some Ford Barners like to use Photobucket. First, setup an account at http://register.photobucket.com/?ref=joinushttp://register.photobucket.com/?ref=joinus upload your pictures then follow the steps below.
1) Double click on the photo
2) To the right of the photo it says "Share this photo"
3) Right click on the code you want copied, usually the img code
4) Once you have clicked on the code it will flash yellow and say "copied"
5) Left click in the message you are typing and click paste
