I installed a set of special 180 degree stats made by Bob Shewman 2 weeks ago to test in my 39 convertible. It turned out to be an ideal time to test them as I searched for the fuel boiling problem. These were easy to install and they go in the radiator hoses at the radiator end of the hoses and fit all early V/8s from 1932 to 1948. They fit snug in the hose and the front end sits up against the radiator hose neck so they need no clamps and will no move. You will need good 1 3/4" ID hoses that are not shrunk, soft or distorted. You only have to drain a little over a gallon of coolant to install them. These have a LARGE flow opening and DO NOT RESTRICT the coolant flow like all other modern stats with small flow openings which cause elevated temperatures in hot weather. They are vented so some coolant flows as soon as the engine is started getting hot water to the stats in less then 5 minutes. The temperature in my 39 remained at 178 to 182 for the entire duration over the past 2 weeks of the fuel testing. These are all copper and brass of the newer wax type mechanisims, not the old bellows type that fail from work hardening on the edges of the bellows. Bob tested them in Pa. at 40 to 50 degree outside temperatures and said they came up to 180 in about 6 or 8 minutes. He is produceing a limited supply at $50.00 per set of 2 including shipping. Contact Bob at gadgiteer@aol.com G.M.
