corvette8n
Picked up a used Snap-on stud remover, was able to remove 14 studs in the same time it took me to get 4 out using the double nut method, only 30 to go.
It is not difficult to remove broken studs. Weld on a nut and back them out.
Yes the stud can be below the block surface. Lot of past threads on the topic, TIG works best. This is just one of many threads:
https://fordbarn.com/forum/showthread.php?t=234086&highlight=stud+removal
Here is one using MIG:
https://www.bing.com/videos/search?...C0F21784642DD237CC64C0F21784642D&&FORM=VDRVRV
Hey Mike Jr. (FL&WVMIKE) It's good to hear from you.
If the studs fight you AT ALL, so NOT push things, or they will break... and then you're SCREWED.
If there is any chance they might break, back off until you can find a torch that will heat the threads up red hot. This will break the rust bond, and they will back right out.
Good Luck!
Your right, it’s amazing how well that works!
In fact if You have a stud that feels like it’s going to break, just cut it off a bit above flush and weld a washer and nut. The heat does the trick.
Good Luck!
Good Luck!
