Dr Brown
Could you send me your testing instructions for gas gauge.
I set up test bench with nos gauge and a used float all King Sealy, I believe.
Using a 12 v battery, switch and single voltage reducer12 to 6v, checking voltage, gauge started smoking.gauge was at full swing.
Everything was grounded, can’t see my problem.
Regards
Skyking
FYI...
i discovered that the some of the dashboard gauge wiring on my '41 involved conductive plates. my research showed, and empirical evidence also showed, that wires with sufficient gauge to effectively dissipate heat (i.e. thick enough) and with the flexibility (thin enough) to do the job don't exist. in that if they are not thick enough heat will melt the insulation, and if not thin and flexible enough it's next to impossible to manipulate them into position. so much so that Ford decided that plates were necessary to do the job. in particular between the fuel gauge and the oil pressure gauge.
… wires with sufficient gauge to effectively dissipate heat (i.e. thick enough) …
