Test Photos by Mercman
Accessory 1939 Mercury full Stainless Steel Hubcaps.
Before and After shots of an original Survivor Australian 1939 Mercury Town Sedan. Judge for yourself if the big dollars spent were worth it? I don't think so.
The rear of the same Survivor 1939 Mercury Town Sedan, Before and After shots.
This Wire Wheel, complete with Locking Hubcap and Strap is on display at the Early Ford Foundation Museum in auburn Indiana. The only problem is that the hole for the Valve should be mounted at the top, and everything would be perfect.
Regular 1939 Mercury Hubcap and the Accessory full Stainless Steel version.
Complete set of Hubcaps for the 1939 Mercury. They comprise of the early issue "Ford Mercury" and the later revised "Mercury 8" varieties in both the regular issue and the full Stainless Steel Accessory Hubcaps.
Fully restored Australian 1933 Ford Coupe with correct Schrader Valve in the correct location. Also has the correct Locking Hubcap.
1959 Ford 2-door Country Sedan.
Another take on the 1959 Edsel Corsair - as a Two Seater
