Bobant
The tail lights on my car only work when the switch is in the high beam position-4 o'clock position. At 5:00 o'clock position I have low beams with no tail lights.
Brake lights work fine.
DO you think I have a problem with the contacts in the wiring mechanism at the bottom of the steering column?( note sure what it is called)
