I think, and may be wrong, that the removable bell / clutch release casting attached to the late T9s can be used to mount a T98. The T98 is longer than the T9 and will interfere with your rear cross member (probably). If you just want a synchronized transmission, use the heavy or light duty 3 speeds available at the time as they bolt in with no cutting required.
