KULTULZ
POWER-GEN seems to be the most popular swap. It goes straight to the OEM GEN MTG BRKT. They will tell you in the in the INSTR what size wire to run to the starter solenoid and any special circuit you will need for the INST LAMP/GAUGE.
The MOTORCRAFT 2G ALT was a fire hazard. It was replaced by the 3G.
The neatest conversion I have seen is one guy took a 1G ALT (has external fan), painted it black and put a restoration GEN DECAL on it and when you looked down it appeared as the stock GEN.
And don't forget the BAT and wiring. It has to have a good amperage BAT.
