Been messin' with a '16 Model T that has a '24 engine. Couldn't turn the crank so removed the head and see the engine has original bore and no marks on top of the pistons. I have poured Marvel Mistry Oil through each cylinder and it now runs through into a pan on the floor. I have also removed the bottom plate of the engine. I have pulled on the crank, tried to lever the rods from below and used a 2 X 4 block to hammer the top of each piston but haven't been able to move them. Loosened one of the rod cap nuts but can't get the other one free on the middle main. The front and rear mains are difficult to reach and I am trying to avoid removing the engine. Sure would appreciate any suggestions. Thanks
