bnchief
I have had this car up and running, with old style points and condenser but the points line up so terrible i put new points in modern upper plate wireless bottom plate made sure bottom plate was not grounding out to distributor body also checked upper point plate to make sure it was not grounding out. Car ran perfectly, bill stipes distributor cam petronix 40,000 volt coil epoxy filled 12v neg ground. Shut the car off put engine pans on car would not start 12.4 volts at coil move point(yes they are opening) no spark checked points with ohm meter it appears that the points may be grounding out should i check this with the distributor wire un hooked from the coil? Was also thinking may have gotten a bad spot where the wire goes thru the armored cable. What is a good modern condenser to use in case i have a bad one we have napa and o'reillys here where i live.
