My 30 coupe has alot of vibration. Decided to check the motor mounts. The front one consisted of a big rubber donut on the center stud under the front yolk. The donut just sits on top of the crossmember. It actually comes up around the bottom of the pully in front. On the bottom of the crossmember where the stud comes through there is a piece of 1 1/2" square metal that acts as a washer on the stud just under the nut. The square has a slot in it where the stud comes through. There are no springs anywhere on it. The back mount appears stock although the rubber parts are cracked and hard. I will replace them with them with new stock rubber pieces.
The crank handle actually lines up well. I'm new but I have searched everywhere to find a similar setup and can't find anything like it. Could it be a farmer fix, or some older aftermarket setup? I plan on just replacing the front mount with a new stock setup with the springs. Could this be causing my vibration problem?
Bill
Bill
