296 V8
Cast iron black pipe here, plumbed all the way back with assorted elbows, unions & never-seez.
Jack E/NJ
Jack E/NJ
I have straight pipes on my 59 292. It had a little too much sharp edge so I made some 5" baffles and stuck in the end of the pipes. Its just as loud but a softer tone. Straight pipes make music!My 56' Merc Y- Block straight out the back sorry not a Flatty ....but sounds sweet...
OL Ron how small a pipe do you mean exactly? 2 inch ID ? Or smaller?The smaller the pipe the higher the velocity of the exhaust, and yes a nice cam like the L-100 makes a big difference.
What do you mean by black pipe? Like for natural gas plumbing in buildings? And if so what the hell does that weigh?Cast iron black pipe here, plumbed all the way back with assorted elbows, unions & never-seez.
Jack E/NJ
That iron pipe must weigh a ton!I would say 1 1/2" would work fine for a stock or near stock engine. Another thing is higher compression, that will make a bark.
In highschool I had a 33 Chebby with a black iron pipe exhaust, my Dad was a plumber.
I agree with the 1.5 or 1.75 pipe statements. I will try to get some video of the difference in sound between them. I think it also depends on your manifolds as well.
36. I'm running stock manifolds, 2into1, 1.75, glasspac, all the wayout to the back. Sounds great, I would suspect just straights would be just a bit louder as the glasspacs don't do a lot really.
Tinker why are you running 2 into 1 instead straight dual exhaust? And do any of you guys use any sort of equalizer pipe in the center of your duals?
Yeah now I getcha . Flatties sound awesome no matter how ya runnem I think.And YES loud is not always good. I swapped bikes one day with my buddy who had a really loud HD half hour later I was all done with that crapThe 36 is a stock motor and I just wants a little more sound out of the decent stock exhaust system I already had. So I had from the canister muffler back replaced. Not a huge difference at idle, but a little more punch (sound wise) when you get on it. I'll try and take some video at lunch today.
mirage>>>What do you mean by black pipe? Like for natural gas plumbing in buildings? And if so what the hell does that weigh? >>>That iron pipe must weigh a ton! >>>
Nah. 1-1/2" diameter gas pipe is less than 3-lbs per foot. Throw in a few pounds worth of elbows & unions and it's still not much. I suppose if you thought your flathead might sound and breathe better with 4" thickwall sewer pipe, that might get you up a quarter ton or so. 8^)
Jack E/NJ
Excellent idea! Can we see some pix of that gas pipe exhaust please Jack?I'm a plumber and I'd like to see pictures of that.
