Thanx Jack cant wait!mirage>>>Can we see some pix of that gas pipe exhaust please Jack? >>>
Yup. Will do. I gotta new digicamera I've been wanting to test out.
Jack E/NJ
I agree with the 1.5 or 1.75 pipe statements. I will try to get some video of the difference in sound between them. I think it also depends on your manifolds as well.
36. I'm running stock manifolds, 2into1, 1.75, glasspac, all the wayout to the back. Sounds great, I would suspect just straights would be just a bit louder as the glasspacs don't do a lot really.
Tinker why are you running 2 into 1 instead straight dual exhaust? And do any of you guys use any sort of equalizer pipe in the center of your duals?
You don't need an H or X pipe on a dual exhaust set up for a flathead V8. I was told by a professional custom exhaust man that the H pipe is best used on GM small block V8's and X pipe used on Ford small block V8's. This guy has done all of my custom exhaust work an he installed an X pipe on my mustang (289 with headers).
On our flatheads we run reds headers with dual exhaust and the short Brockman Mellow Tones, no H or X pipe needed.
8BA in my 41 PU. Isky Max1, Offy heads & intake. Holley 390 and Red's with 12" JONES glass packs. No tail pipes yet.
http://www.youtube.com/watch?v=52IpQIFBLIA
As requested, the attached PDF shows cast iron black pipe exhaust front to rear on a 38 standard. Crossover first plumbed for a 265 in 1960. Then replumbed for the original 221 two years ago. Same pipe, unions & elbows for over 50 years. Don't forget the never-seez if you go this route or disassembly will be tough. 8^)
Jack E/NJ
NICE! Look spretty inexpensive tooAs requested, the attached PDF shows cast iron black pipe exhaust front to rear on a 38 standard. Crossover first plumbed for a 265 in 1960. Then replumbed for the original 221 two years ago. Same pipe, unions & elbows for over 50 years. Don't forget the never-seez if you go this route or disassembly will be tough. 8^)
Jack E/NJ
The car may sound a little loud on the outside, but it's actually quiet inside since the exhaust runs all the way to the tailpan:
Tink I don't know how to post a Youtube video yet but got to Youtube and put this in the search block.Great videos and nice vehicles/flatheads! It's interesting the differences in small changes (in the exhaust) make on the sounds. Would be nice to hear some rev'ed up.
