I just received a set of Stipes shocks and there are no instructions as to their use. Does anyone have a set of instructions or aren't there any? I emailed them but no reply. I'd like to get them on this weekend. Thanks, David
MMMM I did receive a set of instructions with mine. Let me dig around on my book shelf. I just bolted mine up and away I went. They should be engraved "clockwise and anti clockwise" On of our senior tech guys in the club said not to mess with adjusting them. Just bolt and go. As I recall in the instructions it says how to adjust if needed.
Detailed adjustment instructions are in the Service Bulletins. This reference to looking in the book is not politically correct to some. But there it is. I also agree that you should use them as delivered from the factory.
The instructions Benson posted are what came with my Stipe Shock. Ensure you check the adjustment, two of mine were open more than the ¼ turn stated in the instructions.
Thank you very much Benson for the instruction sheet,that is very helpful and thanks everyone else for their help. Ruth,I will check them for adjustment for sure. Thanks for sharing that. David
