Terry NJ
A while ago, I posted that my coupe idled very smoothly but rev it up and it seemed like the hammers of hell were under the hood. It seems slightly better these days. I read in another thread that if the points were too close, it can create a similar situation. I checked the points, yes, too close! I gapped them to a loose .018. Nothing! Same vibration! I ran it with the vacuum gauge on it. Idle is a perfect, steady 21/22 inches. Not the slightest drop! Then I revved it up to 1200/1400 rpm (I'm guessing here) and the gauge was all over the lot.
Sticky valves? Valve float? Gas feed issues? Or what? This is really annoying. I've put MMO and ATF in the crankcase. One thing I've noticed is that the vibration has less intensity or moment to it as the engine gets hot, But it does not go away altogether.
Terry
Terry
