TerryNJ
Being unsatisfied with job I had done, I bit the bullet and started all over again. Only now I took some measurements. The original worm's spline had a coarser tooth. The new ones from Argentina had a finer tooth. The shaft, miked across the grooves was .865 (old shaft) with the new grooves it was .864. There may be an error in my measurements. Anyway, this time I filed the shaft where the teeth made an impression for the length of the splined section. Next I tapped it as Mitch had done and with a torch, vice, clamped to beat hell, and a BF wrench and a pipe wrench, I drew it up as Mitch and Steve B. said. Just about getting it on all the way, I discovered the the body of the steering column (Outer shell) was an 1" too short. So my column is 38 1/2" long and the old one that came with the car is 37 1/2" long. What's that about? Roadster? Pickup? I worked the play out of it down to maybe 1/2". It's done and tomorrow it goes back in.
Terry
Terry
