Franchise_24
Is there a way to test a starter switch once it is off the top of the starter to make sure it is still good?
Ok thanks guys. I think I may have an electrical problem somewhere. The car was running Thursday and it just died on me, and when I step on the starter it does not turn over, even with a battery charger attached, so time to do some diagnostics.
put the charger on the battery to make sure the battery is fully charged.
Bob
1. Test One: Try placing vehicle "in" 3rd gear with switch "OFF" and push car forward to test whether or not starter gear may be locked into the ring gear and will not rotate with 6 volts.
I bet your starter pinion is jammed on the ring gear. Before you take anything apart, put it in 3rd gear, push it either way, to see if the engine will turn. If it is stuck, be sure to push it rearward to free things up.
Just a jovial thought to try to make you smile with your Model A agonizing experience.
Do you have an election in progress in your area coupled the installation of a political campaign sign that you just installed in your front yard?
I knew a guy who installed a small campaign sign out front during a local election, and the next morning his car was sabotaged leaving no air in his (4) tires.
Anything can happen these days. LOL
