C26Pinelake
Re: Starter Swtitch
Try the crank as Paul said. Wayne
I knew a guy who installed a small campaign sign out front during a local election, and the next morning his car was sabotaged leaving no air in his (4) tires.
Anything can happen these days. LOL
That short could blow a fuse or smoke the charging circuit wires, but should not have stopped the starter from turning, unless it killed the battery.
Also what happened with the flywheel jamming when turned in one direction?
If the battery was good then the short should have blown a fuse or smoked the wires. Since the wires didn't overheat I suspect a poor connection at the battery posts or ground. It may have corrected itself during the troubleshooting, but if it happens again you know where to look.
