All,
Thank you for your advice. Here is what I did:
I recharged the 6v Optima battery and tried again with the right cables...nothing. So, I took the old solenoid, right cables, and a $5 starter that I purchased at a swap meet and bench tested it. Because the $5 starter slowly turned, I am suspicious of the starter currently in the car and/or connections, so I will pull it out during the weekend and bench test it.
Does anyone know how to test the armature and the field coils so I can rebuild it? Thank you.
--Conrad
