dfclimber
Went to start the A today and initially starter spun strong. I pulled it back down as I forgot to turn on the gas (I run it dry after each use). I tried to again start it and nothing. No starter spin/engagement, no sounds , nothing. I DO NOT HAVE FUSE ON STARTER
Lights worked fine (and did not dim) when I raised the retard the start level to start her
Charged the battery for a few hours-nothing
I tried adding a jumper cable from ground to a bell housing bolt to rule out a bad ground
Used volt meter at the starter cable and there is voltage and it does not drop when starter level moved manually.
Tried the rocking maneuver in 3rd grear written about on this site and (what to do when A stops running)- nothing
ROLL STARTED HER AND SHE RUNS FINE -but after driving in both forward and reverse ---STILL NO STARTER SPIN.
Suggestions?
Suggestions?
