bmwillia
Ok...
I have minimal wiring. Neg Battery to Solenoid, Starter cable to other side of solenoid. Wire from battery side of solenoid to resistor then resistor to coil.
My problem is that the starter will turn the motor when the plugs are not in but when I put the plugs in the engine will not turn over.
I have good voltage(6 volts) to the starter and a good ground.
Any ideas?
Do I need to rebuild/replace the starter?
Thanks,
Brad
Any ideas?
Thanks,
Brad
