I've replaced many a spring without any spreader as several have described so far. Here's my description with pictures:
After resting the frame on jack stands so the wheels are off the ground I leave the axle hanging on the shock absorber and lift the end of the spring with a bottle jack just enough to take the pressure off of the shackle bolts. Nuts can be removed before or after placing the bottle jack.
Then remove the shackle from one side.
Then the other side. (Spring end did not budge a bit - held by the bottle jack.)
Lower the bottle jack and the spring slowly reaches it's limit of where it wants to bend to. No "boing" or nothin'.
(Reverse procedure for installation)
On one occasion when doing this I intentionally knocked the bottle jack out from under the end of the spring that it was supporting just to see what would happen. It moved down the 2-3 inches it wanted to and stopped. No big deal. Nothing like what would happen if a spring spreader snapped under the tremendous pressure that it is under trying to
stretch the spring instead of just
deflecting one end of it as my approach does. By my rough physics calculations it takes 10 times the pressure to
stretch the spring as it does to just
deflect one end at a time. Just imagine what would happen if a spring spreader either snapped or slipped off of one end when under so much pressure. The pressure would launch the spreader in its entirety or in pieces in any direction to skewer whoever was handy.
