glennpm
Anyone know what torque I should use to bolt the ring gear to the Columbia differential case? The bolts are 3/8"-16 and heads have no marking except for the letter "M". The typical torque spec for a Grade A bolt with these threads is 10 ft-lbs. Seems awfully light but maybe that makes sense since they're also secured with lockwire.
Any bolt head that has a manufacturer's mark and nothing else is a grade 2 bolt. For 3/8-16 the torque for grade 2 is 20 ft-lbs.
Glenn
