i clean mine in a small coffee canbout half full of gas, let it soak an hour or so in the can cover the can with some thing, shake the can good then remove the cable wipe off with a rag, blow off with an air nozzel then do it again, when done soak the cable in kerosene or diesel for a while dry off then lube and put it back inif the cable is real bad i bet the outer cable has a lot of crude in it to, if so take it off the car and clean the inside of it with kerosene of diesel, blow out good with air, use mechanics wire to run all the way thru the outer cable, tie a piece of cloth on the end of the wire and pull it thru the cable several times
