In the early days, car manufacturers recommended using caustic soda to successfully clean radiators & interiors of cast iron engine blocks -- extremely dangerous chemical when one is not extremely knowledgeable & careful for use of same -- can cause severe skin burns, loss of sight if splashed in eyes, plus ruin a good Model A paint job.
Years ago, had an original Model A radiator, (28 years old or so at that time), that overheated to about 210 degrees that I cleaned & subsequently used for years -- about 10% of the old radiator tubes were cut, pinched, & soldered -- fins on front looked like somebody shot at a pheasant, missed, & hit the front of the radiator which experienced only gravel roads -- this particular radiator when looking through the top, looked like the former owner greased the water pump every month with a full tube of axle grease -- the cure suggested by many at that time was to empty half a box of "**** & Span", fill with water, & run it for a couple of days -- then flush with clear water whereby the water did come out looking like jet black sewer water -- next, add remaining half of "**** & Span", fill with water & run for a couple of days -- flush again with clear warer -- both times, lots & lots of soap suds -- Model A radiator opening appeared to resemble the mouth of a dog with a severe case of rabies, foaming at the mouth, which was splashing on the windshield while running down the highway -- but afterwards, the coolant temperature came down to 180 degrees when measure with a commercial laboratory thermometer.
Probably will not work in all radiator cleaning cases to clean radiators, but worked for me. Still have the car & this show piece radiator.
