I wonder what size fitting and where I could get it, to screw into my 8ba sensor hole? That is what I am going to do! Slick setup and hidden! Thanks man!
And Craig, there's still room for your gloves. Wayno
Since those pictures were taken I've also added a mechanical oil pressure gauge in the glove box as my dash gauge reads way low.
I was thinking of doing the same thing. My oil gauge I don't trust either and before picking up a new oil sending unit it would make more sense to just install a hidden gauge.
Yes I do have an IR laser heat gun so maybe this weekend I will check with that and see where its at.
This is the best way to go in the short term to identify if you do have a problem .Yes I do have an IR laser heat gun so maybe this weekend I will check with that and see where its at.
