Dave in MN
I was ordering parts and noticed...
a "NEW" item listed on Snyders website.
announces that their NEW, FULLY UPGRADED CONNECTING RODS WITH REPLACEABLE
BEARINGS are now available for both Model A and Model T applications. The combination of modern, high quality materials and technological improvements allow these components to be suitable for Stock, Performance and Racing applications.
Snyder's is making and selling new insert bearing connecting rods. The insert bearing shells have the side thrust surfaces as part of the insert component. I ordered a set to study and use. The sizing of the insert bearings are available in standard through .040 undersize. I will follow up with comments when they arrive early next week.
Snyder's Insert
Interesting...note the two relief channels in the side thrust surface to allow oil to flow to and wet the area. I spoke to Snyder's this morning regarding the fit of the piston pin. They stated: Rods have the wrist pin bushing pressed in, oil holes drilled, and rough bored. You MUST hone the wrist pin bushings to match the wrist pins in your pistons. Shoot...I was hoping they would pre-fit them to the pistons they sell.
Cost is $75.00 each with a set of insert bearings at $110.00 on their website. Cost of set of 4 with insert bearings $410.00, no exchange, compared to the cost of their babbitt rods set at $236 plus the cost of shipping your old rods to them for exchange...about $14.00. So $250 for babbitt vs. $410.00.
I will put these rods in a test engine this month and report on the results.
It's good to have options!
Good Day!
Dave in MN
www.durableperformance.net
PRESS RELEASE
After two years of engineering, tooling and actual road testing, Performance Engineering proudly announces that their NEW, FULLY UPGRADED CONNECTING RODS WITH REPLACEABLE
Snyder's InsertInteresting...note the two relief channels in the side thrust surface to allow oil to flow to and wet the area. I spoke to Snyder's this morning regarding the fit of the piston pin. They stated: Rods have the wrist pin bushing pressed in, oil holes drilled, and rough bored. You MUST hone the wrist pin bushings to match the wrist pins in your pistons. Shoot...I was hoping they would pre-fit them to the pistons they sell.
Good Day!
Dave in MN
