I would like to start work on my 29 AA engine soon. I'm a self employed machinist with a mill and lathe. If I take a stock model A rod and a new Snyders flange type insert bearing, can I make them work? I can make a fixture that will hold the rod perpendicular to the spindle and bore it out, measure it with a starret inside mice. Would anyone know the bore size?
For years I'v heard of using 283 gm pistons on A rods. I have a Seal Power catalog, engine parts specifications. The compression distance of the A piston is 1.906", I measure one and that is correct. The cd on the 283 is 1.780" depending on which one is used. The difference is .126", that would be too much of loss in compression. Please give me some more info on this subject.
Thanks, carry on, nick c
