slight cooling system leak
Ah a little coolant leak isn't a problem, less it's in the oil and makes it milky.
Tighten everything you can get at and see if that helps.
I have a pin hole leak in a radiator that puts a few drops on the motor when I start it up over the winter. It's annoying for that startup after 5 months dusting the engine bay with a fine mist. After that it's fine for 7 months. Never effects the coolant level, few drops. Guess I would ask, how much coolant are we talking about?
Best of luck.
