Yes Frank, more information is needed here. We are not mind readers and we are not standing looking at your engine. If your coolant level is just going down and no visual leaks are showing then you could have a blown head gasket or a crack in the engine block and your water is going out the exhaust pipe. Pull your spark plugs and see if one looks very clean compared to the other three. Do a compression test on all cylinders or do a pressure test on your radiator with the correct pressure tester and check to see if there is a leak down. When you have done all those tests get back to us. Just dont guess on this DO THE TESTS. Regards, Kevin.
