I am hooking up signal lights to my 29 ccpu. I have the front wired. I have 6 volts going to the lights when the signal switch is deactivated. When i activate the signal switch the volts drop to 3.66. Same way on the rear. Do I have a bad flasher or signal switch. I ran a direct ground from the battery ground and the same thing happens This is a signalstat switch
