signal stat 900 question
Jimczeb
I just purchased a Signal Stat 900 used. I think the moded is 25-00101.
I have looked everywhere but cannot find a wiring diagram that matches the configuration or the wire colors that match the unit i have. Can anyone help?
Find attached a picture of the unit.
Jim Czebiniak
I have the signal stat 600 on mine, I'm not sure if they're wired the same or not. But, on mine all the wires had tags with letters on them. I have the function of each wire letter written down in my notes in my garage. When I get home from work I can dig them out and put up what I have if yours are labeled that way too
Attached are the instructions from Snyders for the Signal-Stat that they sell. I would think that they would be close enough to get you in the neighborhood.
Also a diagram I found using the search "Signal Stat 900 wiring diagram", there are a bunch out there.
On the 600:
Yellow/black: + to stalk light
B: ground to stalk light
C: - Left signal
D: + to turn signals
F: - Right signal
From the looks of it, I'd say the 600 is different though
