flat-v8
Not much to look at,,just me driving my old '32 Sedan. HRP
This is the car,,
That's alot to look at! Beautiful car!
This is the car,,
This is the car,,
That is a sweet looking 32 you have there.
To show your picture larger than the 800 X 600 pixels that you can upload you need to save your picture to an online service. I use PhotoBucket: Then copy your picture from that website and paste it into your FordBarn post. Then it will show as big as the website you copied it from showed it. PhotoBucket limits width to about 1200 pixels but that's more than big enough to see.
296V. Is that engine in a car? If so how does it go? That engine intrigues me. I had a 296 back in the 50's. I had an Almquest cam, 3 94, Lincoln converted dist, I used 1/8LC pistons instead 3/16 pistons, the pistons popped up over the top, had to dome the heads, Had wicked compression. that engine was awsome in a 39 coupe. WaltHRP
Is that a weird shadow or a ponytail ?
DONE4, that a beautifull B engine. Is it in a car? What's in the engine? Does it have the cast counterweight crank or the later pressed on counterweights? What's that head, nice job polishing. Thanks WaltJust my little banger going back into the deuce, finally.
Way to go Henry! Love it! I always thought your car was black! The fresh air heater is a nice accessory.
First one Avatar! The rest after last winter total rebuild as a 40's 50's build. Love the car now!
Here's mine. Steve
That is a sweet looking 46. I bought one of those tank door moldings and put it on my car 46 Sedan. What do you have for front hubcaps. I can see some sort of cone on the front end. Looks cool.![]()
This is the car,,
Here is mine...
Here's mine. Steve
Thanks for the kind words-I appreciate it. I removed the hubcaps and using a bullet center cap.
