BILL WZOREK
Does anyone else suffer from this while working in the shop?
I heated up a frozen part with the Oxy / acetylene torch got it loose then set the torch down then turned around and grabbed the part to clean on wire wheel.
I guess there is a Bad ground or loose connection between the brain and the hand / Brain said LET GO / LET GO NOW
The hand said WHAT ????
Needless to say the brain proved it point OUCH !!!!!
