Steve Plucker
Does it make a difference if the distributor points are set in the retard or advance position?
Thanks.
Pluck
Thanks.
Pluck
If you are talking about gap, as previously stated, the answer is no.
If you are talking about timing, you set timing in the full retarded position.
Chris W.
Does anyone have a dwell spec for a Model A? I know we all THINK we can hit .020 exactly when setting points, but I'll bet if 10 of us set the point gap at .020, we'd have 10 different dwell values. It would be great if we could double check our work against the "official" dwell spec.
Spark happens when the points open. If the gap is too close, the points open later making the timing more retarded. If the points are open too far they open early and make the timing advanced. If you set the timing with the points set at .020, when you reset the points you know the timing is on.
Chief sed, "A worn Dime for the points & a worn Nickel for the plugs.A hacksaw blade is near enuff....
Chief sed, "A worn Dime for the points & a worn Nickel for the plugs.Close enough for all practical purposes & Farm Equipment
Chiefs' Son
12&16 cylinder engines have to do some other method because you can't open far enough and close long enough that many times in 360 deg. at highway speeds. Fun stuff.
