pooch
Yep, I am playing with a ford sidevalve V8 ATM and learning it.
It has 45 degrees of rotation for each cylinder and spec is 36 degrees dwell, so the (dual) points are only (both) open for 9 degrees.
I doubt a single set of points could do that at 3400 RPM crank speed 1700 dizzy speed..
Although 30 years ago before I knew how dual points work, I threw out the second set on my 302 and it ran fine on one set.
A model A would not care too much about dwell having 90 degrees to play with and only 2200 RPM crank and 1100 dizzy.
