Wilbur
When the brake pedal is depressed on my 29 Fordor, the cross shaft strikes the bottom of the torque tube, right away,and raises the whole engine/trans slightly.
I found the rear engine mounts to be slightly loose and figured that would cure the issue. It didn't. I have never had the drivetrain or engine out of this car. Is it possible that the front mount is too high? Is this a common problem?
