Licensed to kill
That is my thinking as well. To those that warn of the legal implications of "altering the VIN in any way", are you suggesting that grinding off the VIN from a replacement engine and restamping it to match the number from the original engine or frame is Illegal??. If so, then when registering the car, do you use the frame number or the replacement engine number? If you use the engine number (because that is the visible one) what happens when the VIN is discovered to be for a 1930 coupe and your car is a 1931 sedan?. If you use the PROPER frame number, would you not fail an inspection because the VIN on the engine doesn't match the registration?. Seems to me that you are just looking for trouble by NOT updating the engine VIN to match the car.Putting the correct number on the legitimate engine in your legitimate car is not "altering the manufacturer's serial number" in any way.
California's laws are different. Stay out of that state. Don't listen to anybody from that state. Don't let your daughter marry anybody from that state. Anything you eat or use in that state probably has a warning that you will get cancer.
Of course I may be biased, being from Minnesota where everybody is above average.....
Sound advice.
